There are no staff members currently online.
[DICA] What is Intel ME Region:
ME (Management Engine Stands or Manageability Engine) is a driver are stored in the BIOS and only on the recent Intel platform (Core i). ME was first built in network card then transferred to the chipset (GMCH, then PCH, and MCH).
- ME is stored in the BIOS source however it works completely independent from the main CPU.
- ME works even when the computer is in hibernation mode or turned off but still plugged in the machine.
These errors arise when the ME Region fault or not activities:
+ fan always runs at full speed 100% Full Speed, CPU temperature is always set at 100%.
+ Machine starts after 15-60 seconds and display comes after 15-60 seconds
+ Machine runs 30 seconds, 1 minute or 1 hour or 2 hours sometimes, automatically shut down or automatically restart.
+ Computers are not very Windows, running crashes, run magnet offerings can be unloaded from the ME Region faulty.
If after replacing PCH that meets pan arises is as if you are comfortable on the right to replace it with a BIOS was not beating Clear ME or ic chip to generate additional miscellaneous hardware failure.
This was the reason that you need BIOS Clear ME.
O que é a região Intel ME:
ME (Management Engine Stands ou Manageability Engine) é um driver armazenado no BIOS e apenas na plataforma Intel recente (Core i). O ME foi construído primeiro na placa de rede e depois transferido para o chipset (GMCH, depois PCH e MCH).
- O ME é armazenado na fonte do BIOS, mas funciona completamente independente da CPU principal.
- O ME funciona mesmo quando o computador está em modo de hibernação ou desligado mas ainda conectado na máquina.
Esses erros surgem quando a região ME falha ou não atua:
+ ventilador sempre funciona em velocidade máxima 100% velocidade máxima, A temperatura da CPU é sempre definida em 100%.
+ A máquina inicia após 15-60 segundos e display vem após 15-60 segundos
+ A máquina funciona 30 segundos, 1 minuto ou 1 hora ou 2 horas às vezes, desliga ou reinicia automaticamente.
+ Os computadores não são muito Windows, travando, as ofertas de ímã de execução podem ser descarregadas da Região ME com defeito.
Se depois de substituir o PCH que atende pan surge é como se você estivesse confortável no direito de substituí-lo por um BIOS não estava batendo Clear ME ou chip ic para gerar falhas de hardware diversos adicionais.
Esta foi a razão pela qual você precisa do BIOS Clear ME.
Usuários Online neste Tópico: 1 Visitante(s)
